Case C series ??
XT180
I recall running a DC and a RC for several different area farmers back in the early '80's. Were there other "C" series of that Case era ?? Thanks
The C, D, R, S, V, & VA series were Case's standard tread models. The CC, DC, RC, SC, VC & VAC were the same tractors, only in row crop models. There were also industrial & orchard models as in DI & DO for the D series. The R series & V series did not have Case designed motors. The R series used a Wakasha and the V series used a Continenal. The VA series was later, looked similar to the V series, but had virtually no common parts. VA's had a Case designed motor. The C series was replaced by the D series & shared many common parts. The S series replaced the R series and was a completely different tractor than the R.
Got a CC and model C back operating a couple years ago....
Thanks for the replies gentlemen !! I do recall another neighbor with a VAC :) Can I make the assumption that the "lower" in the alphabet, the higher the HP ??
