Case 530 power steering pump-utility model
I had recently posted about my power steering on my 530 not working and gained a lot of information. I have the single cylinder set up and was able to get it all apart....it was a rusty, tweaked up mess but I was able to clean everything very well and get a new seal kit for the control valve so that I could put it back together. It is back in the tractor and I am going to get a few hoses made up to test it out. Question I have is about a rebuild kit for the pump in the event mine is bad. I don’t have the canister style pump that comes up when you look up the pump in the manual, and I know there were numerous steering systems and unfortunately I have no idea what year it is due to having no serial plate. It does have a model 31 loader and the single gauge cluster with all the gauges in it. Any info on the steering pumps is appreciated. I also need a set of fenders....
I rebuild those bendix steering assist units for the 300,400,and 500 series in case you hit a snag.
Bob
The pics you previously posted matches an early 530 built 1960 to 1964 prior sn 8262800. Gear drive PS pump original Case p/n G45466 sub to G45467 with a remote reservoir/filter. The pump is NLA via Case but you may be able to find a suitable substitute if reqd.
What part was a "rusty, tweaked up mess", the control valve mechanical actuating parts or the internal oil system? It appears you may have the heavy duty axle, are the ends of the axle curved toward the rear of the tractor?
Joe
My actuating components were a mess but with some elbow grease and patience they all cleaned up. Waiting on a set of hoses to be made up and we will give her a try.
