Case Tractors Discussion Forum |
1170 Fuel Injectors
Author |
[Modern View] |
DG 3
07-22-2020 17:37:42
I am in the process of trying to replace the injectors. I was able to get 3 of them out by prying on the fuel line tube several times back and forth until they freed up enough to pry up on them. The other three are so tight I can barely move them back and forth and even broke the fuel tube off of one. Is there a puller for those? Any other ideas? Thanks in advance for any help!! I really appreciate the help all of you have given me so far!!
dwag
07-24-2020 14:20:56
Re: 1170 Fuel Injectors in reply to DG 3, 07-22-2020 17:37:42
Take the guts out of stuck injectors, grind down piece of 5/16" redi rod, drive in and weld to inj. Use pipe/spacer & nut to pull inj. PIA but would help to remove water & ex manifold. 50/50 mix acetone and ATF excellent loosening agent.
DG 3
07-25-2020 18:17:18
Re: 1170 Fuel Injectors in reply to dwag, 07-24-2020 14:20:56
Thanks!! I will try that. I really don't want to pull the heads
Dieseltech
07-23-2020 04:23:30
You might need to pull the head and drive them out from the bottom end. There are two seals on pencil injectors, the top one holds compression IF there are NO nicks/burrs where it seals at both head and under the injector banjo inlet. The lower seal is a carbon dam to keep carbon from sticking injector into the head bore, it DOES NOT hold compression, but WILL leak if the top compression seal leaks. When injectors are out, if there are ANY nicks under banjo area, or bent that injector is history, can't be cleaned/reset and used again. A 3/8 drill bit can be used to clean the head bore after injectors are out.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO
... [Read Article]
Latest Ad:
combine ih 303 403 101 151 503 615 with grain plat header control
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
