Company Logo (800) 853-2651 Shop Now
430 front axle pictures
Bruce from Can.
07-18-2020 15:09:34
Got my new tractor home, Cade 430 triple range diesel , with blade $1,200.00 . Needs some love, but it seems complete, and has oil pressure.. I had written earlier about the very heavy front axle, in comparison to the 430 gas I had many years ago. So here are three pictures of the tractor. Third Party Image
Third Party Image
Tires are fair, hood and nose look rough, needs a splish splash of colour appropriate paint, and it will look a lot better. Steering is very heavy, and tie rods are worn and I think the steering shaft is a bit seized in the bushing below the steering wheel. Something to play with.
Third Party Image
Case Nutty 1660
07-19-2020 04:58:34
 Re: 430 front axle pictures in reply to Bruce from Can., 07-18-2020 15:09:34
Just the early style Utility axle they also came with flanged rear axles,, much stouter for loader and backhoe apps, same as the 530 used at that time a shot of my 1962 G430 that uses the same axle, mine also has power steering Third Party Image
Don Rudolph
07-18-2020 19:34:37
Yup, same front axle as that truckload of 430's sold by our dealer. I remember the spindle and hub extending out like that. It reminded me of a trailer plow axle hub. Don
Ward1989
07-18-2020 19:06:15
I have a 430 with the same front end. To make it wider and more stable i flipped the front tires/wheels 180.Works good for me.
Jal-sd
07-18-2020 18:43:52
Are the spindles off-set to the rear to enable the tractor to turn shorter? Is that why the axle looks like it was bent to the rear in the pictures?
casecollectorsc
07-18-2020 17:14:47
Looks like you did good! Red paint or not....tires would make up a lot of the 1200 and they look very good also.
bradley martin
07-18-2020 15:23:19
Looks like a very good buy, Bruce! Without knowing the serial #, I would guess a 1960 or 61 model. I have seen that axle in the parts book, but have never run across a tractor with it. Enjoy.
