Company Logo Shop Now
430 diesel fuel cut off
c125bob
07-16-2020 10:25:51
I need a fuel shut off valve, the one on the bottom of the fuel tank. mine is damaged and can't be rebuilt. Any ideas on an aftermarket valve or does anybody have a good used one. 1965 Case 430 diesel with 188 engine
Thanks !
mEl
07-16-2020 19:23:18
 Re: 430 diesel fuel cut off in reply to c125bob, 07-16-2020 10:25:51
My 530 is the very earliets design with a single filter on the tank bottom, I will send a pic if all goes well, hang on!
kevinstuff
07-16-2020 16:54:16
Well my 530 has a radiator type valve on bottom
of tank , but thatís to drain off the water that collects in the diesel fuel , Then there is the fuel line and itís shut off also connected to the tank higher up .
c125bob
07-17-2020 02:43:50
 Re: 430 diesel fuel cut off in reply to kevinstuff, 07-16-2020 16:54:16
Thanks for the picture. I think I found a good used one.
mEl
07-16-2020 15:00:12
125, I have a 530 with the original single filter body under the tank, that gave me trouble so I went to the hardware store and picked up a 3/8 th inch 1/4 turn brass ball valve and hardware to screw into where the present drain goes and hardware to get down to the line size at the filter line, Lots more volume since 3/8 comes out of the bottom, if you wanted to have a drain you could use a Tee out of the tank and put a valve on the bottom. I will try to add a pic in another note.
c125bob
07-16-2020 15:47:21
 Re: 430 diesel fuel cut off in reply to mEl, 07-16-2020 15:00:12
Ive been thinking about that and if i cant find one thats the plan ! if you get a chance a picture would be great. I may have a good used one located, hope so.
Thanks !
Copyright © 1997-2020 Yesterday's Tractor Co.
