Company Logo Shop Now
Re: Case 310B Clutch Pedal Rod
aDave
07-15-2020 18:53:09
Well, I thought I'd come back and provide a brief update:
After a small hiatus from dealing with the tractor, today we finally got a chance to install the replacement clutch pedal rod that we received. After a bit of tinkering and getting it installed, the wife hopped on the tractor to depress the clutch and test what we'd done. Upon doing so, "SNAP!" The just-installed rod broke in the exact same spot as the old one. Right at the 90 degree bend that goes into the linkage where the clutch rod ties in.
Fortunately, in my part search, I'd actually gotten two, so the second one was installed. I'll keep it short...things went well and the test drive of the tractor was fine.
So, at this point in time, it looks like things are okay...so far. Not having a back up part, I'll be contacting Jean Claude who let me know earlier in the thread that he had some.
Here's a photo of where the break was on our most recent rod. Was this a weak link on the tractor? The wife, who spends most of the time driving it hasn't noticed it being excessively hard to depress the clutch pedal. Or, is this just bad luck?
Thanks again.
Joe (Wa)
07-15-2020 20:36:20
 Re: Case 310B Clutch Pedal Rod in reply to aDave, 07-15-2020 18:53:09
I've had a 1959 311B & a 1956 310 for about the last 20 years, they both have that rod. The 310 spent most of its known life doing loader work on a dairy farm, notably scooping manure in the barn an adjacent areas. They both have done a lot of loader work since I have had them also putting a home site in a heavily wood 6 acres so the clutches got a workout. I have had to replace worn down clutch friction disc on both, also replaced pressure plate & release bearing while they were split so they clutch operating linkage has been worked. No signs of the rod fracture you have.
I have the linkage well adjusted as per that diagram I posted. I suggest you do the same if you haven't already done so. Breakage like that would appear to be from a twist as the clutch pedal is pushed down, something to eyeball.
Joe
Copyright © 1997-2020 Yesterday's Tractor Co.
