Here's the deal. I have a model 291B loader that is mounted on an early 530. I want to mount the loader on my 611B. I have the operators instruction manual, but it leaves out a lot of details. One question I have is whether or not I remove the side rails, the piece of steel that is bolted to the bell housing on one end and the front bolster on the other end, or leave them on? The 530 doesn't have these rails. When I remove the loader from the 530 do I need to find a set of these rails to put on the tractor, or is this something I can live without?
The 611B has power steering that uses a power steering motor in the steering linkage. The mounting bracket is bolted to the side rail. If I do have to remove the side rails where do I mount the power steering motor? The sub frame of the loader has a large square hole where the steering motor should bolt on.
Well, that's what I have for now. I'm sure more questions will pop up later.
