Case 990 selectamatic hydrostatic steering
Hello, I am in need of a Track Rod ( tie rod ) inner tube - right side when sitting on tractor. I think the part number is K912709. The Track Rod ( tie rod ) is for 52 - 76 inch track width . If I cannot find the inner tube, I would be interested in the complete Track Rod ( tie rod ) the space tube ( outer tube ) would be 35 inches. I think part number k912708 not sure about this . I do not know the part number for the complete assembly. These parts are for a Case 990 selectamatic with hydrostatic steering. Thank You for any help.
First thing I'd do is start searching Ebay. After that do an internet search for used David Brown parts. If you want to spend a good bit more, go to Messicks website, look up the 990 Selectamatic under the Case/IH section and see if you can order the part. I'd look it up for you, but the parts system is down as I type this.
I went out to my parts repository. I have one complete unit, to include both track rods and the spacer tube. But I can't get it off tractor using a pickle fork and hammer (believe me, I tried). I would have to haul the oxygen acetylene torches out there to apply some heat. Too much work. Sorry.
(reply to post at 07:12:48 07/26/20)
Thanks for the reply and effort. I have acquired a tie rod however the ( inner tubes ) or ends of the tie rod are seized up and I cannot adjust them. I have tried all the tricks that I know. Haven't give up though. If you or anyone that reads this has any magic mono tricks that will work, please let me know.
