1070 Brakes
DG 3
All of a sudden I have no right brake. Left one works fine. The rod on the back of the brake pedal that goes to the power brake valve is very floppy. Has something came loose in the valve? What will I need to do? Thanks in advance for your help guys!!
There is a nylon retainer that holds the pushrod for the brakes to the pedal linkage that can fail allowing the pushrod to fall out of place., you will probably have to remove the valve to get good access to install the new retainer, they can fight you.
