Company Logo (800) 853-2651 Shop Now
Can a Case expert fill me in on this?
J Hamilton
07-05-2020 19:50:59
I seen this listed on Tractorhouse and I'm confused on this. Could a Case expert explain? I understand the LP tank just could have been replaced or reconditioned in 59, but the tractor serial number has me stumped. Thanks
Don Rudolph
07-05-2020 20:40:41
 Re: Can a Case expert fill me in on this? in reply to J Hamilton, 07-05-2020 19:50:59
It is probably a converted DC3 gasoline tractor. Case offered LP conversion kits to retrofit older models to LP, although you could get a factory equipped LP gas D series starting in the summer 1951. I was told that in 1953 gasoline down south was 19 cents a gallon and LP gas was 5 cents a gallon. Therefore the demand for LP equipment. Not many LP gas DC's w/AWF. Mine came from Texas. Don
casecollectorsc
07-06-2020 04:50:09
 Re: Can a Case expert fill me in on this? in reply to Don Rudolph, 07-05-2020 20:40:41
My son has a DC awf propane he bought on a auction about 50 miles from home in MN. 52 DC that the son of the owner told us his dad bought the propane kit from JI Case to switch from gasoline. Everything was in the kit including the hood and cylinder head. Factory propane tractors have a angle iron across the front of the tank for the headlites...this one pictured doesn't have lites.
Don Rudolph
07-06-2020 06:51:10
 Re: Can a Case expert fill me in on this? in reply to casecollectorsc, 07-06-2020 04:50:09
In the conversion kits you could go with the 6128 LP head or continue to use the gasoline head at a slight reduction of horsepower. I have the LP kit installation manual that gives a parts breakdown and step by step guide to installing and tuning the LP equipment.
casecollectorsc
07-06-2020 16:13:29
 Re: Can a Case expert fill me in on this? in reply to Don Rudolph, 07-06-2020 06:51:10
Good find! Have never seen that manual.
DKase
07-05-2020 20:03:51
1953 DC. If you believe the 1000 hours you had better jump all over it. Barely broke in?? Hand, or foot clutch?
J Hamilton
07-05-2020 20:20:58
 Re: Can a Case expert fill me in on this? in reply to DKase, 07-05-2020 20:03:51
It's not likely to believe everything that they say about equipment on there, especially the hours. The serial number had me confused because I don't have an accurate listing by years and doing the math didn't seem right to me. And it's listed for $3200 which is a lot too much in my opinion.
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally ... [Read Article]
Latest Ad: 1959 Case 210B has a loader, hydraulics hoses are 3 years old,have a back blade, duals, brush hog and finish mower for it. Runs good but has a little hydraulic leak - not bad enough to make me want to tear it apart. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
