90/94 series cases ac leaking water in cab
Had that happen in my 2394 last week. Turned out the hose barb that the hose goes on was completely broken off the bottom of the
drip tray. Looked like the previous owner had messed with it before. Sure would have been nice if the tray was replaceable like
the 70 series! I did get it glued on with JB quick and it does not leak. Pull the air vent out nearest where it drips and you will
be able to tell if the leak is from above the tray. If it is the top of the cab will have to come off. You will most likely find a
mess in there that needs cleaned out.
Hey, when did you get a 2394?? Lucky guy! We need pics...course maybe I missed its arrival. Had a chance at one on a auction a few years ago and couldn't force myself to pull the trigger.
6 years ago. Needed something bigger for the planter, cultivator, and silage chopper. Thought you had been here since then?
U must have one of the latest 94's as ones I've dealt with had drip pan available through AP Air. or good metal fabrication shop.
