Company Logo Shop Now
90/94 series cases ac leaking water in cab
jicaseman89
07-04-2020 17:02:51
Yup leaking water in blew hoses out still leaks in to cab
jicaseman89
07-05-2020 10:12:04
 Re: 90/94 series cases ac leaking water in cab in reply to jicaseman89, 07-04-2020 17:02:51
Ok thanks guys I figured some one has messed with it before haha
DKase
07-04-2020 18:38:19
Had that happen in my 2394 last week. Turned out the hose barb that the hose goes on was completely broken off the bottom of the drip tray. Looked like the previous owner had messed with it before. Sure would have been nice if the tray was replaceable like the 70 series! I did get it glued on with JB quick and it does not leak. Pull the air vent out nearest where it drips and you will be able to tell if the leak is from above the tray. If it is the top of the cab will have to come off. You will most likely find a mess in there that needs cleaned out.
dwag
07-06-2020 18:31:34
 Re: 90/94 series cases ac leaking water in cab in reply to DKase, 07-04-2020 18:38:19
U must have one of the latest 94's as ones I've dealt with had drip pan available through AP Air. or good metal fabrication shop.
casecollectorsc
07-04-2020 19:11:17
Hey, when did you get a 2394?? Lucky guy! We need pics...course maybe I missed its arrival. Had a chance at one on a auction a few years ago and couldn't force myself to pull the trigger.
DKase
07-05-2020 12:25:00
 Re: 90/94 series cases ac leaking water in cab in reply to casecollectorsc, 07-04-2020 19:11:17
6 years ago. Needed something bigger for the planter, cultivator, and silage chopper. Thought you had been here since then?
casecollectorsc
07-05-2020 14:22:00
 Re: 90/94 series cases ac leaking water in cab in reply to DKase, 07-05-2020 12:25:00
Possibly, probably wasn't paying attention.
jicaseman89
07-04-2020 18:31:28
Alright hows the best way to access that tray top of cab I assume??
Thanks
Case Nutty 1660
07-05-2020 05:39:02
 Re: 90/94 series cases ac leaking water in cab in reply to jicaseman89, 07-04-2020 18:31:28
sorry i forgot to add that but I see DKASE added the info Thankfully
Case Nutty 1660
07-04-2020 17:12:49
drain holes on the tray plugged and or you blew the hoses off the drip tray outlets
Copyright © 1997-2020 Yesterday's Tractor Co.
