Company Logo Shop Now
1070 Brakes
DG 3
07-01-2020 17:56:15
All of a sudden I have no right brake. Left one works fine. The rod on the back of the brake pedal that goes to the power brake valve is very floppy. Has something came loose in the valve? What will I need to do? Thanks in advance for your help guys!!
mEl
07-02-2020 04:03:58
 Re: 1070 Brakes in reply to DG 3, 07-01-2020 17:56:15
There is a nylon retainer that holds the pushrod for the brakes to the pedal linkage that can fail allowing the pushrod to fall out of place., you will probably have to remove the valve to get good access to install the new retainer, they can fight you.
DG 3
07-07-2020 06:45:26
 Re: 1070 Brakes in reply to mEl, 07-02-2020 04:03:58
Thanks for the info!
Adirondack case guy
07-02-2020 16:10:18
Mel likely nailed it!!!! Check the lead screw stops on pedal when you replace the nylon retainer.---------------Loren
DG 3
07-07-2020 06:46:24
 Re: 1070 Brakes in reply to Adirondack case guy, 07-02-2020 16:10:18
Thank You!
Copyright © 1997-2020 Yesterday's Tractor Co.
