Company Logo Shop Now
Re: 1967 Case 730 Comfort King
mEl
07-01-2020 08:24:52
[quote="CVPost-crankin12864"](reply to post at 10:17:25 07/01/20) [/quote
Did you check all 4 outlets? the right side couplers have thermal reliefs which can fail under certain abusive circumstances. this will cause low pressure and implement leakdown. Other than that, the couplers and hitch work off of the same relief valve and share a common pressure setting so even if the hitch seems to go up normally it would not lift an implement of any weight.
crankin12864
07-01-2020 08:32:50
 Re: 1967 Case 730 Comfort King in reply to mEl, 07-01-2020 08:24:52
I have a Drum mower on the 3pt right now and it lifts it without any problems - It weighs 1,000 lbs.
I have tried the upper remotes, 300 psi on both of them. Gonna try lower remotes today and check the pressure on them.
I suspect the pump is good because I seem to have decent flow, just not much pressure.
Copyright © 1997-2020 Yesterday's Tractor Co.
