Year and model
Hi all. New to this site. We just got used case but Id tag is gone. Anyone have idea of year and model? Need to get manual. Thanks
(quoted from post at 17:33:36 06/28/20) Sorry pics didnt load first time
It usually won't let pictures post until you have at least 5 or more posts on record. You can keep trying, use the test area - way down at the bottom of the page if you want, you'll get there.
(quoted from post at 15:48:28 06/28/20) Could use some more clues. More pictures from different angles would help. Is it gas or diesel?
Gas. Ive been trying but pics having hard time loading
Thanks. That gives me starting point. Looked up tractor data site and had no data on tire size or Hp. Im gonna keep digging
210B has separate gages, not cluster and battery is under hood. Not 310B either pic is 1958, note sheet meatal
battery is under battery door in front of dash and narrow chrome stripe on side. The sheet metal difference
between 310B 1958 & 1959 is the 1958 has radiator door while 1959 radiator is taller and filler neck & cap is
above the grill top.
Transmission shift pattern has "S" for start and wide black sheet metal stripe so a later tractor maybe 430? or
did early 530 have cluster gauge? No shifter "R" equals shuttle.
Joe
I have a 210B and it's not that. Like Joe said the 210b has individual gauges and doesn't have a lift off battery compartment door for the battery like yours. It has a little door on top of the hood barely enough space to reach the battery with jumper cables. It's
marked 300 but I don't believe it's that either. The 300 also has the little battery compartment door. Maybe a 500.
(quoted from post at 04:20:13 06/29/20) I have a 210B and it's not that. Like Joe said the 210b has individual gauges and doesn't have a lift off battery compartment door for the battery like yours. It has a little door on top of the hood barely enough space to reach the battery with jumper cables. It's
Battery sits on the floor between pedals
Any other resources to look beside tractor data.com?
Ive looked at every model from 1950 to 1970 and nothing matches. Most front tires are 5.5 16 where mine is 6.5 16. Buddy at work was thinking 60s 320 or 520 industrial.
it Also has 6 bucket not 40. If it had a backhoe on it at one time wouldnt it have a pivot seat? This on is fixed.
I had two CASE W3s yours looks the same. I still have one. Neither one had ID tags on. I think they built them for about 3 years. Somewhere around 1961. They were built a little heavier than a 530. Mine both had front end loaders that were self leveling also backhoes.
Thanks. I talked to case dealer and said sounds like 530. Id plate is on right side of console and one missing on the frame by left rear tire is engine plate. Both are missing. He said its probably 189 motor and allot of the distributors were the same. He use to work for J I Case back in the day
