Company Logo Shop Now
Re: Case 411b transmission
mEl
06-24-2020 08:11:13
Neither, the pipe that goes straight down into the cap, comes up and curves front is the pump outlet pressure line which goes front to the cooler and filter, the other pipe comes straight back to the control valve and feeds the valve which contains main relief, the fitting there has the TC gauge connection on the rear of the tee, , there is also another valve we have not talked about and that is the little valve on the top cap next to the main control valve, it's purpose is to set the TC pressure, a low pressure control valve in the 30- 40 LB range or close to there. In my opinion I would look for a main relief sticky regulator spool or quite possibly the cold oil relief cartridge could have failed. There is really no way to ascertain if TC wear is the problem without opening it up so I would look at pressure till I eliminated that as the cause.
Copyright © 1997-2020 Yesterday's Tractor Co.
