Company Logo Shop Now
Re: 990 Case injector pressure and push rod length
gwayne919
06-21-2020 20:19:27
I thank you for sending me the useful link and after sticking a tiny cam down the hole I was not surprised at how much wear the cam had suffered and what I only suspected after seeing the concave end of the push rod. The usual chamfered sides of the rod weren't even evident and the wear on the camshaft must be at least .050" deep. I'll be adding .040" to the 36MM length to compensate a bit for the loss of cam lift. That shouldn't be too much to damage the diaphragm. This engine had suffered with a power steering leak into the crankcase for a long time before I bought the tractor of which I replaced the seal. I'll keep an eye on the oil and pwr steering fluid levels until I know there is no longer any problems there. Poor design. Maybe the injection pump also leaked internally as it did externally. When I got the tractor home I operated it for a half hour and the crankcase oil level was up very high from acceptable when I tested it. Thanks again.
Copyright © 1997-2020 Yesterday's Tractor Co.
