Company Logo Shop Now
Re: 1370 issues
Eric in IL
06-20-2020 11:25:52
cnt,
I appreciate your reply also. It bears the same value as 1370rod's reply.
The reason his made sense to me was my experience replacing a broken pedal spring on a 970 many years ago. I fought that spring for an hour with various pairs of vise grips to no avail. I could get it so close, but never quite stretched enough. I finally called a neighbor that was an IH mechanic. He told me of the trick to put coins between the coils on each side of the spring. They were not easy to insert, but after you did that the spring was long enough you did not need to stretch it at all. Just install it, then step on the pedal and all the coins fall to the floor.
So thinking of that experience, I thought someone not knowing the trick might have given up and found a lighter spring than was stock. Just a guess.
I think I will try using some cable lube on the pivot point to start with. I think the graphite in the lube might last longer than a light oil.
Again, as I said in my original post......Thanks for the help to all that reply.
Case Nutty 1660
06-21-2020 06:46:47
 Re: 1370 issues in reply to Eric in IL, 06-20-2020 11:25:52
gotcha,, I guess I have been doing them so long its old hat to me,, my first hours in a 70 Series came in 1969 at the dealership,, I also happen to own over a dozen of them lol as for lube I do not use "light oil" its about worthless for lube I only use the same thing I use in all my engines HD cnh 15-40wt dsl oil,, but use what ever you feel will do the best job for your app,, I installed lots of the springs with a pair of vice grips but use the washer method if I have them handy,, I lube any pivot point or spring attaching point,, makes things last decades longer,,
Copyright © 1997-2020 Yesterday's Tractor Co.
