Case 430 id issue
FSA1953
I received a Case 430 Utility tractor from a family member It seems to be missing the data plate off of the instrument panel. Is there any other way of Identifying this? There's a data plate on the block near the oil pan #2003091 and on the left arm of the loader Model#22 Serial#4069073. I'm trying to maybe get the correct serial # for this tractor so I can order the correct parts.
Thank you
Julian
The closest I can get you to the serial number of your tractor
Is 1962 . I checked the serial number registry and found the
engine number 2003078, And the serial number was
8194636. . Chuck Machinist Let me or others here on the
forum know if we may be of further assistance. Best of luck
