Hi all,
New user, first post. Just acquired a Case 380. The transmission clutch seems to work fine, I can shift into and out of gears 1, 2, 3 & R. The PTO clutch however does not seem to disengage. When I depress the clutch pedal fully, trying to move the pto lever results only in grinding. I thought I would crawl under the tractor and take a peek at the clutch through the access panel, expecting to see an old, worn out clutch. Instead I see what appears to be a brand new one. Any ideas? Anything I can do or check short of splitting the tractor?
Thanks,
Jim
Thanks,
Jim
