Case SC Throttle Issues
c.amick
06-04-2020 16:17:41
I worked the SC pretty hard yesterday plowing. The engine now revs way up when I just barely move the throttle. Could the carburetor throttle plate be loose. When I move the rod between the carburetor and the governor by hand, it takes very little movement to make the engine rev way up.
c.amick
06-07-2020 20:18:17
 Re: Case SC Throttle Issues in reply to c.amick, 06-04-2020 16:17:41
I took the governor off today. The sleeve that slides on the shaft was not sliding as far down the shaft as it should, when the weights spin and pull on it. I guess it was caused by lack of lubrication? Tractor runs fine now.
flatpkr
06-05-2020 04:57:35
You have a governor problem.
Jim
c.amick
06-04-2020 20:10:20
My other thought was, could I have cracked the manifold? I got pretty hot.
olgentdc
06-04-2020 19:35:30
The governor is not hooked up right.. you will need a book to set it right
c.amick
06-04-2020 20:08:10
 Re: Case SC Throttle Issues in reply to olgentdc, 06-04-2020 19:35:30
Something must have broken in the governor, if that's the problem. I has ran fine for years.
olgentdc
06-04-2020 20:12:54
 Re: Case SC Throttle Issues in reply to c.amick, 06-04-2020 20:08:10
Maybe , never had one fail me yet , but have heard of some that broke.my guess is spring?s . If it were mine i would double up on the procedure to set the governor .. before tearing down the tractor
c.amick
06-05-2020 18:25:30
 Re: Case SC Throttle Issues in reply to olgentdc, 06-04-2020 20:12:54
Thanks for the replies.
