Case 90 series rear lights
karl h
I would like to add rear lights on the top of the cab on my 2290. The wiring is already there behind the flasher light and i believe there should be a bracket to mount the light to that was offered as an option. Does anyone have the lights that could describe the bracket or how it would have mounted from the factory
It mounts using the 1/2" bolt hole behind the flasher & the wire spade terminal is right by it also. The bolt hole probably has a plastic insert to protect the threads and the spade terminal should have a rubber boot over it. The original mounts are just like the front cab corner ones. I just made my rear brackets using painted angle iron on the 20 & 23.
Brad
I have bought the replacement lites at Runnings. Apiece of painted angle iron like 560 said should be almost like the original bracket. Mine are on my 4690.
