I just bought this yesterday and will pick up today, very clean straight sheet metal, missing the left gas tank cover and the eagle in the grill, screens are there but bent some, very good rear rubber with I guess the eagle hitch and drawbar, engine is stuck, has been sitting in a lean to, took a plug out and was running rich but no rust or moisture, gas is very old and smells rotton , oil looks new and full of antifreeze. I will get it home and set to soaking the cyl with atf and diesel mix and see if I cant get it loose, are these typically good hp tractors for their size? I have to be honest and haven't had much exp or luck with case tractors I have bought in the past, thanks for any insights on this, have a great weekend
