gtwildbill
New User
I recently purchased a DB 1210 and it has been working great until yesterday. It acted as if it had a dead battery. I tested the fairly new battery with a digital VOM and found the voltage to be fine. I cleaned the battery terminals and the opposite connecting points at the starter and chassis ground with a wire brush and reassembled.
The tractor then started fine but the charging lite is on.
I let it run a while with my meter connected to the battery and watched the voltage steadily drop. I double checked the connections and they are good. I checked voltage at the alternator and found the larger gauge wire reads battery voltage obviously as they are connected at the starter. The lighter gauge wire reads only 2.14 volts.
So it is now not charging. Any help or ideas?
