Nosepicker
I recently pick up a case 530 gas tractor with a loader. I am having a weird issue with it. it starts and runs great. when I roll the throttle on and start to use the loader to scoop with it will begin to bog and stall as though it is running out of fuel. I cleaned the sediment bowl and am wondering if there is not enough fuel flow coming from the tank into the sediment bowl. when I open the valve to refill the bowl there are two small streams of fuel that are present. it seems that the sediment bowl may be plugged partially where it comes from the tank. the tank is very clean inside. any input would be appreciated.
