Case 930 3 point
I just changed the hydraulic fluid and
filter (Hy-trans) on my 67 comfort king
930. The 3 point will not raise unless the
tractor is almost at full throttle. Idle
to half throttle it won't move. What is
the deal?
I believe the 2 speed lift poppet in the 3 pt valve is plugged up. It is behind the plate on the right side of the 3 pt valve. Do not mess with it without a service manual.
Thanks I'll look into that. The old oil was very nasty and yellow,I think it got moisture in from setting. I figured the hy trans would be a good replacement because of the additives to repel water
