Case 430 3point issue
My 430 developed an issue. Has attached front end loader whish is working fine. My son notified me that the 3 pt will not lift the disc more than a couple inches. Everything worked great the past couple weeks. Had him check fluid level, etc. I am a truck driver and only home weekends. Only a couple weekends left to finish our fields and am looking for suggestions on what I should have him check to hopefully pinpoint any issue, so it is ready to use after the weather breaks for us.
Any ideas where we should start?
(quoted from post at 06:44:18 05/22/20) Is fluid level Low ? Could be the cylindar is by passing and needs reworked
Fluid level is fine. Was wondering if maybe needed bled since front end loader still working fine.
Not sure how your system is set up, but the loader and the rock shaft may not be on the same hydraulic system. One system may have gone bad and the other system is still fine. Otherwise the spool valve, a stuck open pressure relief ball, or the draft setting may have been changed.
Oops, disregard the unhooked hose suggestion. I missed the part where you said the 3 point was at fault. I assumed a wheeled disc with a remote cylinder.
