770 bleeding brakes?
Midalake
I just put two new rubber brake lines on and can not get a pedal. Pumped brakes, had tractor running a few spurts????? Powershift trans. Do I need to press clutch in? Idle higher? Is there another bleeder somewhere other than on the piston? thanks!
Dave
Is it a power brake tractor,if so just open the bleeders and let it sit there and run it will self bleed if everything is right, if standard brakes you will have to keep the master cylinders full and someone pumping the brakes and holding pedal down while you crack the bleeders.
So it looks like I do have a master cylinder calls for a case fluid of Automatic trans type "A" fluid. Any preference and how much does it hold.
Thanks Dave
