Getting my dads case 1960s 430 gas tractor going after idle for years. Rebuilt carb. Now spark is intermittent. Had to remove distributor as cover
would not remove easily. Have a j. I. Case shop manual..
I am new to tractors and ignition systems, but Trying to follow installation and timing in manual.
Which is number one piston? Forward or aft?
Does static timing procedure ensure the spec of 4 degrees BTC?
There is intermittent on opening and closing of points as seen from voltmeter on distributor to ground when cranking. Did new coil, points, capacitor.
What kind of oil/ grease goes into port on side of distributor?
Thanks for any help.
Norm
Norm
