Transmission cooler line
jstpa
Need to replace the steel line running from the torque converter housing to the radiator on an 801-b. Does anyone know what fittings these take, are they jic,sae, or something else. Thank you, jstpa
If you remove the flare adapter fitting from the pump and control valve where the lines are hooked to now it is pipe thread,, 1/2 I think off the top of my head they are
cnt
Thank you. That's what I needed to know. I guess I could have figured that out, but now I can have everything ready to go when I want to rep!ace it rather than tear it apart and then go looking for fittings.
