olgentdc
one of my 430 diesels has developed annoying problem , The
starter solenoid will not keep the starter drive engaged into the
flywheel ring gear .the starter spins free but the drive will not
stay engaged long enough to start the engine. I think the drive
is at fault But Not sure ? Which componet is at fault. is the
solenoid failing to keep the drive engaged ? or is there sprags
inside the starter drive that are stripped and are failed ?
