Got the 4490 up and running and used it to anhydrous 250 acres but have an issue with hydraulics. It only raises implements when clutch is pushed in. Changed hydraulic pumps and checked pressures according to manual but still nothing. Noticed there are several pressure sensors on the hydraulic filter top.
The case manual has 20 pages on troubleshooting the 3 pt hitch but very little on the remotes. It just says check pressure and flow. Pressure and flow are great when clutch is pushed in.
Need help. Thanks
Need help. Thanks
