730 vs 830 case case o matic comfort king
All,
Looking at buying a 730 or 830 case. What were the pros and cons? I heard that they have head gasket problems?.. Looking at two with 3 points to move 1200 lb bales with 3 point carrier. Also to pull a rowse double mower. We hay about 500 acres.
Sold them new and own a number of both never have seen one single head gasket fail that was installed Correctly, now you can crack heads by not allowing them to cool down properly before shut down,, both good units,, depends on how much power you want to which model to buy
cnt
I had an 830 caseomatic diesel and it was a
very good tractor. I never had any head
gasket problems. The caseomatic
transmission was good for plowing,
disking... etc, but I didn't care for it
for mowing
All around a great tractor, and that is for every use, if you like a automatic transmission, you will love Case O Matic. Keep the oil change on the transmission, and take care of it and it will take care of you.
