This is a follow up to previous threads that show disassembly and a parts diagram:
how do I remove shaft from this seat torsion?????
and
Re: how do I remove shaft from this seat torsion?????
The following photographs show the broken parts and wear I found afetr taking everything apart:
The pivot bolt is severely pitted
One torsion spring rivet plate got chewed open
The boss broke out of the side plate
Both side plates had elongated holes at the end.
I can't see just bolting everything back together as-is. I'll do what I can to weld the boss back onto the side plate straight and fill/redrill the elongated holes. Be back with more photos when I'm done. Probably sometime tomorrow.
Sometime in the future I will see what I can do about getting a new pivot bolt and bushings but for now, these will have to do. Shouldn't be hard to replace any part ... once it's back together with these unseized pieces.
and
