I have a 1956 Case 311 thats fitted with a front bucket. When I try to lift the bucket it will raise approximately 4' in the air, then one of the cylinders freezes while the other cylinder continues to try and raise the bucket. This causes the bucket to lift farther on one side and stress the metal.
I have checked the hydraulic fluid and it's full.
If my memory is correct, it seems the hydraulic set up for this tractor is a little different than modern day tractors.
Any ideas on what's causing this and what I can check??
Thank you!
Thank you!
