LaBoyteaux
Thank you Loren and Brad for information on the 1030 exhaust gaskets. They are on the way.
Next item is a 530 Case-o-Matic radiator. I think this tractor was rolled or some violet incident on the right front. Although still running, one radiator mounting bolt was torn off, the mounting support cracked, the core scarred by the fan and the whole radiator generally tweaked. I think a replacement better and less costly than repair. The Case-O-Matic radiator not so easy to find on line
and I noted that the aftermarket replacements don't seem to have the little brackets to attach the sheet metal on each side. So I'm in the market if someone has a good used one or knows a source.
