2590 injector line leak
E SCHOEN
Where the line screws onto the injector it was seeping. I tightened it a little but now it?s shooting a fine mist out. Are there o rings in that fitting or does the line probably have a hairline crack?
No O rings on high pressure line at pump and injectors, probably cracked. Even if not cracked line may need replaced. Case, AC, JD, and some White diesels used Ermeto line end sleeves that are a pain compared to the sixty degree line ends. I replaced two Ermeto lines on my neighbor's White 2-155 last week because no matter what was done two injectors would not stop dripping. New lines fixed it.
