Company Logo Shop Now
Corn planting done...
casecollectorsc
05-02-2020 21:04:39
52nd year planting corn is done. Also a picture of my JI Case TC-68 planter that was my first 30" planter in about 79. Had a wide row Case 434 before it and a 400 Cyclo for about 20 years. This 800 CIH cyclo planter is a big upgrade from the 400.
jon f mn
05-04-2020 04:01:32
 Re: Corn planting done... in reply to casecollectorsc, 05-02-2020 21:04:39
I've got a few acres left. Got over an inch of rain that slowed things some. Looks good this week tho. That 8 row case is really something and would be fun to have.
John Saeli
05-03-2020 09:30:40
Very wet here, no corn planted anywhere. The best planter is sitting in the grass. To this day, there isn't another planter that has as good a seed to moist coil contact as the K160 unit. Seed is always in the very bottom of the "V" trench, not covered w/ dry dirt.
Mark-IA
05-03-2020 05:34:33
Corn is up and most beans planted in Central Iowa. Getting very dry. Dust and dirt blows across the fields when they were being worked.
Gene Dotson
05-03-2020 04:47:30
Still waiting for a dry spell here in west central Ohio. Haven't seen a corn planter in my area. Rain every other day.
Gene
casecollectorsc
05-03-2020 05:24:24
 Re: Corn planting done... in reply to Gene Dotson, 05-03-2020 04:47:30
That's the way it was last year here in E SD. About normal this year...even on the dry side. Could use an inch of rain once the beans are in. Haven't had only a few tenths all spring for rain.
Jal-sd
05-03-2020 10:10:56
 Re: Corn planting done... in reply to casecollectorsc, 05-03-2020 05:24:24
And we didn't our usual April snow storm in out part of SE SD, either! We have a lot of sub-soil moisture in our part of the world, though. Sloughs are all full but beginning to go down.
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO ... [Read Article]
Latest Ad: combine ih 303 403 101 151 503 615 with grain plat header control [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
