Adriondack I need your help
Josh M.
Location
Northeast Ohio
I have another case plow that I need identified, i know im not sure how my father and uncles lost track of the models numbers on our case plows either. But all I can find is a tag that has patent numbers for the US and Canada and a sticker that says J.I. Case. Im going to try uploading photos of this one too, hopefully it works.
I agree with Ben that it is a JT series 4-B plow. If it is 14" it would be a JT44. If 16" it would be a JT 46. Your plow however is a JTA 4X as it has trip beams, rather than rigid/shear pin shanks.----------------Loren
Thanks, do you know if you are able to still get parts for them? It was a great plow until the wheel bearings grenaded and the wheel fell off, they were an odd size when we looked for them and it seemed like no one carried them, i have no idea where the bearings went since then. I put ford 4000 wheel bearings on it just to get it out of the field but they aren?t correct.
Bearings shouldn't be an issue and even if they were, it would not be much of a job to replace the spindle with something standard. The problem is getting wear parts for the bottoms, especially the 14" ones.
