Just checking to see if anyone knows if the triple range transmission on this 630 with the L on the serial tag for low gear has issues.
The right hand triple range shifter goes into all 3 ranges fine, but each one of them makes no difference on the transmission speeds, including reverse. In other words, the ranges seem to shift into fine, but the gears are all the same speed, so it's not changing the range.
I am wondering if the L on the tag means there is not a triple range? It doesn't say on the tractor anywhere, but the decals are long worn off. Or possible the shifter fork is not working correctly? Or maybe it's not a triple range at all? Any ideas.
It does have the left hand clutch shifter, which works correctly for the PTO. Thanks for any thoughts. Bob
