Hi Folks, My question to all of you guys is,
Is it possible to replace the Throttle shaft seals on a Stanadyne DBGFCC Pump on the tractor.? It's a '76 Case 580b.
Or, is it possible to remove the pump as is, without setting up at TDC, as long as I mark the mount position, and don't move the engine, pump shaft, or anything in the pump besides the throttle shaft seals?
Thanks for you help. Kai
