Hello all, been a while
Need some expert help on 1070 RPS 34
Pressures seem low in all, except C1 in PS2 ???
PS1 C1 = 160 C2 = 150
PS2 C1 = 190 C3 = 180
PS3 C2 = 145 C3 = 145
PSR C2 = 145 C4 = 155
Inching pedal depressed C4 = 140
Lube pressure = 70 in all, drops to zero with pedal depressed
Looks to me like a leak in the C2 circuit, but C4 is low when pedal is depressed
Is it possible to check for leaks without splitting ??
Or is it possible that it can be in the control valve
I have adjusted all the linkage
Tractor does not want to move if you go any higher than 1st gear
in the manual gear selector
Any help would be appreciated
By the way mEL, HOW YA DOIN
