Company Logo Shop Now
Case BH Plow Cylinder
jt501
04-27-2020 09:59:25
Recently picked up a Case BH 3-bottom plow, but it didn't come with the hydraulic cylinder. Can anyone tell me the proper size cylinder for this unit? I checked out the B/BH series parts diagrams already, but they didn't show the cylinder. Thanks for any help with this!
jt501
04-29-2020 08:20:39
 Re: Case BH Plow Cylinder in reply to jt501, 04-27-2020 09:59:25
cool thanks for the help you guys!
jon f mn
04-27-2020 13:51:44
You are looking for a standard 8" stroke hydraulic cylinder. Anything from 3" diameter and up will be fine. Most all older farm machinery used that standard 8" stroke cylinder and most fleet stores or machinery dealers will sell them.
oldproudvet
04-27-2020 13:04:00
I use a regular, common, ol 4" on mine for years. 11 ft disc, 10 ft digger etc, all this smaller stuff uses the same size cylinder. Larry
Today's Featured Article - Massey Ferguson 35 (and up) Tractor Assembly Notes - by Jack Wetmore. These assembly notes are for Massey Ferguson tractors with a two stage clutch and 6 speed, 8 speed and mutli-power transmissions. I see a lot of discussion forum messages regarding damaged clutches from improper assembly. The objective is to have the engine and transmission slide together safely and easily until the gap between the two halves is less than 1/4", BEFORE tightening any of the bolts holding the two together. Using bolts to draw the two halves together will damage the PTO ... [Read Article]
Latest Ad: combine ih 303 403 101 151 503 615 with grain plat header control [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
