Wicksfield
My 1968 830 has dual hydraulics. New Hy-Tran and hydraulic filter a couple years ago. I've noticed recently that the lever to
activate the remote cylinder pushes or pulls hard. Once it snaps into place, it will hold until the cylinder is fully extended or
retracted then pops back into neutral as it should. Both remote levers have the same symptoms. Lever pushes (or pulls) hard into
position. I will say, if I operate the lever back and forth while in the shop, tractor running, with hoses not hooked, only the
first time will the lever push hard. Next time easy as it should. Then, a bit later, pushes hard again. You guys have any idea
what the problem may be?
Thanks for your response.
