Britcheflee
Hello,
I am working on a Case VA or might be VAO there is no serial number - I can post some pics if needed. It has been converted to 12 volts with a motocraft alternator which was run though a VR. There seemed to be some issue with the wiring and things were smoking and melting so disconnected it all. I would like to replace that motocraft alternator with the single wire alternator and remove the old VR (I will replace the coil and resistor in due course) my problem is that all the wiring diagrams I find on line do not show for this exact model which has the switch and also the press button starter like on an 8N - I cant get it to match up with what I have on the tractor. Can anyone in simple terms explain how to wire this up and/or show me a diagram or post a picture of their set up?
This is the existing wiring set up - I have ordered a new set of gauges as these are in really bad shape. The wire on one side of the ammeter is just disconnected as it went to the old VR before.
