Case Tractors Discussion Forum |
How to replace cab mounts, 70 series
Author |
[Modern View] |
petebert
04-08-2020 07:39:20
What all is involved with replacing the cab mounts on a 970? I'm on a quest to make this tractor quieter and a lot of people recommend doing those. The rears are about 3/8" thick and still have some sponge to them. Do you remove the entire bracket that's mounted to the rear axle to do those? The fronts on mine don't look to be in very good shape and look kind of difficult to get to. What about all the cables? If the new mounts raise the cab this is going to be putting tension on the throttle and powershift cables right? Although my PS cable is out of adjustment, curious if this will fix that. Other things I plan on doing to quiet the cab is trying the spray/paint on bedliner stuff, I'm hearing good stuff about doing that. These tractors originally came with material in the control box, mine is of course gone. So going to look into putting something in there. Maybe coating the inside of that box as long as doesnt cause anything to bind. Insulate both sides of the firewall and I'm going to pull the ceiling panel down and see what I can put in there. Mines an early 70's model, I read that the late 70's models had extra insulation up there.
1370rod
04-08-2020 18:53:05
Re: How to replace cab mounts, 70 series in reply to petebert, 04-08-2020 07:39:20
The easiest way to replace the rubber insulators is to remove the mounts they are in. Remove and replace them one at a time. You can jack up a corner of the cab just enough to remove the mount without have to mess with any cables or linkage. Remember to remove the bolt securing mount to cab first and leave the parking brake disengaged so the cable does not stretch. Usually not a bad job unless the bolt is rusted tight in the metal sleeve molded into the insulator. Rod.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
