Case Tractors Discussion Forum |
Case 831 3 point locked
Author |
[Modern View] |
Tedtex
04-07-2020 12:42:57
A new to me 831 has a loader that works fine but 3 point will not respond. The arms are in the lowered position. I can lift them by hand with no resistance. When I let go they free fall drop back down. As I stand on the lower arms and move the control lever, I can feel and see a very slight response but nothing more. Oil level is right on the mark. Is there a control to switch between 3 point and remote cylinder operation? I did a search of this site and read where a small orifice ti drain the oil back to the reservoir can become clogged from lack of use. Any suggestions to fix this?
casecollectorsc
04-07-2020 14:49:12
Re: Case 831 3 point locked in reply to Tedtex, 04-07-2020 12:42:57
Eagle hitch or draft o matic 830??
mEl
04-07-2020 14:08:30
In all likleyhood your lift plunger in the DOM valve is sludged up internally, It will require the side cover taken off the DOM valve on top above the right brake, disassembled and blown out, If you do this your self the internal needle you must remove to clean has a setting so when you take the lock screw out above it first bottom the screw and the count how far it took to bottom it so it can be reset to that dimension, 3/4 turn off it'seat rings in my mind but it's been years. Done many of them, most in the field on road service.
Tedtex
04-07-2020 16:47:09
Re: Case 831 3 point locked in reply to mEl, 04-07-2020 14:08:30
Yes, this is a DOM system. So the lock screw has the needle point on it and I should expect the setting to be about three-quarter turn back from bottoming out the screw, but count the turns to be safe? Using an air jet, I need to blow out the tube that the needle covers. How much oil if any should I expect upon removing the side cover? Thanks
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
John Deere wheels rare pair of A1106R 24 inch solid cast rear wheels 3000.00. Pair of BWH / BNH 40 inch spokes 1600.00 pair of John Deere D front spokes 350.00.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
