What all engines will interchange with a DC
Farmallb
Im looking on E Bay for engines that will fit in a DC Case, but I dont know which model engines will
fit in a DC
(quoted from post at 16:50:21 04/03/20) Im looking on E Bay for engines that will fit in a DC Case, but I dont know which model engines will
fit in a DC
There are no direct bolt ins the older C series shares basically the same bell housing except the Cs did not have a starter except in the industrial I believe, there are DC blocks out there reasonable, and done properly will out live us and parts are out there, why don't you rebuild, unless your block is missing or badly broken rebuild it.
the D series has different tractors. D standard model, DC4 DC3 DI DO. so that should give you something to look at.
mEl, I don't understand what you are referring to. In the 1st link the aft seals 13 & 29 for respective early drive assemblies is in the same location as the later drive assembly seal 52 in the 2nd link. The seal(s) mentioned is the one that seals the main drive shaft from the hyd pump drive shaft.
His tractor has all the indications of being a very early 530. I think I can make out a spring on the hyd pump drive shaft aft of the release bearing in his pic,(Link 1: bottom drive assembly item 15, mislabeled valve spring). Spring like my pic of an older tractor here. That would make the his tractor prior sn 8191147, 1962 or earlier.
Joe
https://partstore.caseih.com/us/parts search.html?csid 223a6f17006f1c28d77c50972e0ca241&sl EN&currency epc::mr60192ar732454bi293650 15
I can do that. I was just checking to see wqhat engines would fit, and at what cost it might be to
buy one.
