Looking for some fuel system parts for 400b
Hello all I purchased a replacement tsx 749 for my missing one on my 400b project but along with the carb I was missing the throttle rod that hooks to it from the fork in the front of the engine. I'm having a time trying to find one, is there anyone that can point me where to get one of these thanks
I would think a "Metalworx" sort of guy could easily fabricate a governor-to-carburetor rod from a length of 1/4" rod and two 1/4" ball and socket ends? Looks like it needs a little kink or two to get where it needs to be! I think the upper style is what you will be trying to copy.
<img src = "https://i.imgur.com/LptxzXs.jpg">
As to the length of the rod, the short/generic version of this is that the carburetor throttle butterfly shaft lever needs to hit it's "wide open" stop JUST BEFORE the governor arm runs out of travel in that direction.
Adjust length of rod between governor and carb to achieve that.
Thanks I have seen this picture and I wondered if this was correct cause I also got some other info from others that was different. I'm not very familiar with the case farm tractors I have restored a few case garden tractors but this is my first bigger tractor so I'm still learning
I tried to email JC using that email and it didn't seem to go through I don't believe has anyone else used that and had success just curious thanks
(quoted from post at 22:34:47 03/30/20) I tried to email JC using that email and it didn't seem to go through I don't believe has anyone else used that and had success just curious thanks
JC PARTS
Jean Claude Marleau
1716 GILLES STREET
L'OrIGNAL, ONTARIO CANADA
K0B 1K0
PHONE 613-632-9445
FAX 613-632-9445
E-Mail: [email protected]
Case tractors &amp; Loader Backhoe parts only.
