Case 580D backhoe
Cole737
New User
I m new to the board. I recently bought a case 580D. It s a mess, to say the least. I could use a schematic, if anyone could help me with that. Regards, Cole
A complete Case Service Manual for your machine should have the wiring schematics, the ones I have for the earlier 580 models do. I very much doubt you will find a free service manual or schematics. If I were you, I would look for a used OEM service manual on eBay or check with Case. Here is a case site you might find a manual or at least the right manual part number. Have your Model and serial number when looking to verify if needed. You can at least get the correct manual part number from the Case site to help in your search. If you purchase an aftermarket manual you may want to check with the seller to confirm it has the complete schematics.
http://www.dmcretail.com/productSearch.aspx
Jim, thanks! I was trying to get off cheap I guess. My employment situation is in flux recently, as is many people. I may have some real time coming up
to work on the backhoe. I will probably need a full service manual anyway. That brakes are bad as well, so it will come in handy. As is normal, the
deeper you dig, the worse it gets.
Regards, Cole
Joe, thanks! I need to bite the bullet and buy one. I could do it without a schematic, but it would take weeks. With one, I can do it in a couple days. And move on to something else.
Regards, Cole
I found one on eBay. All three digital manuals. Parts,
operators and service. Couldn?t get a direct answer as to
being able to print out certain pages. Very hard to work off a
computer and not a paper copy. It was around $20.00 so I?ll
take the chance. Thanks, Cole
